Good News: ZimaOS Total downloads have surpassed 4.1 million! Thank you for your continued support ![]()
This release puts customization front and center.
ZimaOS now feels more like yours — with personalized device visuals, storage layouts, and even the login experience.
We’ve also improved storage reliability with better USB management and a more robust RAID recovery mechanism, along with system-wide stability improvements.
Read the full release notes below:
New
Added customizable display for storage devices
Added USB class storage device management
Special thanks to @SerbanSerba@Igor Ci. @Igor @Chris Panton @Wunjox -
Added reliable saving mechanism for RAID metadata, supporting automatic re-identification and mounting of the original array after system reinstallation or device replacement
Added customizable display for device images and login wallpaper Special @JCShanks to @JCS
Fixed
Fixed the pull restriction issue in the mod_management module
Fixed the connection restriction issue when SMB acts as a client
Fixed the issue where SMB did not “skip folders without share permissions” as expected –thanks@hr_b @JoeSchi
Fixed the issue where disks could not enter normal sleep due to intermittent wake-ups by the smartd service –thanks@kraizelburg @t1ll1s @Rafit77
Fixed the Docker startup failure issue caused by abnormal docker0 network interface
Fixed the Files service startup failure issue due to missing data tables or abnormal table structure –thanks@imbatman69 @James
Fixed the problem where storage appeared missing due to the presence of vfat-type disks –thanks@opantal2 @jopro1
Fixed inaccurate display of the Recycle Bin –thanks@luke
Optimized
Optimized network card information display
Optimized settings page display
Optimized request list handling in ZimaOS when not logged in
Optimized the error prompt text when application pull fails
Adjusted the display order of the seventh drive on official ZimaCube devices
–thanks@journeymangeek @GrimOak.Zima ( NOT A STAFF )
- Optimized the USB device enabling logic; it now supports selecting a mount point when enabling, improving flexibility.
Don’t wait. Upgrade now please!!! ![]()
Best regards,**
IceWhale team
