ZimaCube New Three-Heatpipe Cooling Solution Comparison Test
Dear ZimaCube Users,
The team recognized that the current cooling design standards fall short of what the ZimaCube team aims to deliver. Therefore, we have improved a new cooling solution to enhance your user experience. We will provide this upgrade free of charge to any Backers who require it. This will also become the new standard for future mass production deliveries.
In order to continuously improve system performance and User Experience, we recently conducted a comparative analysis of the original cooling solution and the New Three-Heatpipe Cooling Solution. The test was conducted under controlled conditions to evaluate the differences in noise level and cooling efficiency between the two. The following is the main information:
Test conditions
  • Room temperature: 24 ° C
  • Test duration: 1 hour
Noise level
Full load status: * When the CPU is running at full load, the noise level of the original cooling system reaches 47 dB .
  • New solution: The new cooling system significantly reduces noise, only 33.9 dB .
Standby status:
  • Original solution: In the CPU standby state, the noise level of the original cooling system is 31.9 dB .
  • New Solution: The noise level of the new cooling system has been improved to 30.2 dB .
Heat dissipation performance
Heat test: We conducted a 1-hour baking test under the condition that the CPU is 100% full load and the system default power consumption is 28W.
  • The original plan: the temperature stabilized at about 90 ° C after 1 hour.
  • New solution: The temperature stabilized at about 78 ° C after 1 hour, indicating a significant improvement in heat dissipation efficiency.
Conclusion
The new heat dissipation solution has shown significant improvements in reducing noise and improving heat dissipation efficiency. Quieter operation will bring a better experience to users in noise-sensitive environments. At the same time, enhanced heat dissipation efficiency means longer component life and more stable system performance under high load operation.
We have also seen the positive transformation plans of community users and deeply admire your innovation and hands-on ability. The wisdom and creativity of the community not only helped us find multiple solutions to problems, but also provided us with valuable improvement ideas. Thank you to every user who participated in the discussion and made suggestions. Your enthusiasm and support are the driving force for our continuous progress.
Thank you again for your support and contribution to ZimaCube!Please continue to pay attention to the follow-up developments.
IceWhale Team
Are also going to make this cooling solution available for the users who purchased the Standard ZimaCube?
YES! Additional information! All ZimaCube users can update the new CPU fan for free! Please pay attention to the follow-up email
If I understood the email correctly ‘free!’ = icewhale coupon for device + customer pay shipping, handling, and taxes.
Thank you for your inquiry! Your understanding of the “free” policy is very good. We do provide free CPU fan replacement service, but due to operating costs, postage and taxes need to be borne by you. I hope this arrangement will not cause you too much inconvenience. We have been working hard to provide users with better services, thank you for your understanding and support.
Free New Cooling Fan for Backers
  1. To enhance your experience, we will be launching a free upgrade service for new cooling fans in September, lasting for one month.
  2. The day before the products are available, we will send coupons via email to all ZimaCube Pro and ZimaCube Pro Creator Pack users. These coupons can be used to offset the cost of purchasing fans.
  3. Please keep an eye on your email for further details. While the fans themselves are free, please understand that you will be responsible for the taxes and shipping costs. We greatly appreciate your support and understanding!
I got the device last weekend and tried installing Proxmox. And then I start seeing the device automatically restarted or even shutdown.
Checked the sensors data from the lm-sensor tool and see the highest temperature of the CPU got the 100 ° C. I guess that’s the reason on why it got rebooted or shutdown. And this makes me even unable to install the Nvidia driver in the PVE.
So I’m looking for cooling solution and see this new update here. Good to know this. Hope we can get this ASAP. Can we start this replacement program this week instead of Sept.?
this sounds like your fan may not be correctly seated, have you rotated and repasted the fan? I never hit 100c, ever on stock cooler and pasting. Those that have seem to have had poor pasting or the fan heatsink on stock not sitting correctly because they hit the top of the caps.
I got the backer email, but it appears the free fan is only for Zimacube Pro and Creator Pack users. Will N-100 ZC backers like me have access to new fan also? I have no problem with being responsible for shipping etc.
Thanks for the tip. I’ll check that after I receive my NH-L9x65. Currently the device is shutdown and looks like have some problem. When the device starts up, it would hang and output from the onboard HDMI is blurred. So I turned it off. As my order of NH-L9x65 is already on the way, I’ll try replacing the cooler. And at that time, I can check if the original pasting is poor and see how the new cooler works.
YES!Please wait for the email notification in September.
Just to update this: yes, the screws of the original cooler were loosen. So it was not seated correctly.
Now I also replaced it with NH L9x65.
But still see the temperature goes up to more than 90 when just installing some apps from the zimaos app store. And also set the Fan mode to “Full mode” in BIOS.
https://community.zimaspace.com/t/zimacube-creator-pack-heat-issues/3614
the fan is largely irrelevant
the biggest impact to temps is repasting between the die and IHS - but this is not for the faint of heart
you might get a 2c to 5c repasting between the IHS and Heatsink
I bought the ZimaCube Pro Creator Pack in the store in July.
I did not back the project through Kickstarter.
Will I also receive an email for the free CPU cooler upgrade?
