I was running zimaos 1.5.4 which worked fine. Then I upgraded to 1.6.0. After running nearly 12 hrs server froze. UI or SSH Terminal didn’t respond. Had to cut power and start again. Same thing happened after nearly 12 -16 hrs. Then I upgraded to 1.6.1. Still the same problem exists. Now I am switching back to 1.5.4.
Any similar incidents? I am using 1.6.1 in Zimaboard 2 which works fine. But 1.6.1 did not work without being frozen in Zimaboard 1.
Same problem here with my Zimacube. how did you downgrade, im concern about the raid 5 its mount it with 72tb….is there’s a way to downgrade without information lose problem?
