root@ZimaOS:/root ➜ # dmesg | grep -Ei “ata|sata|btrfs|md|raid|error|fail”
[ 0.000000] Command line: BOOT_IMAGE=(hd5,gpt4)/bzImage root=PARTUUID=a3ec664e-32ce-4665-95ea-7ae90ce9aa20 rootwait zram.enabled=1 zram.num_devices=3 net.naming-scheme=v250 systemd.machine_id=5c0aa80748604afa81ce94ceeac4b0a6 fsck.repair=yes console=tty1 quiet splash loglevel=3 systemd.show_status=1 rd.udev.log_level=3 net.ifnames=0 biosdevname=0 intel_iommu=on vfio_iommu_type1.allow_unsafe_interrupts=1 thunderbolt.host_reset=false rauc.slot=B
[ 0.000000] AMD AuthenticAMD
[ 0.000000] BIOS-e820: [mem 0x0000000076213000-0x0000000076222fff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000006ce5d017] usable
[ 0.000000] reserve setup_data: [mem 0x000000006ce5d018-0x000000006cf18a57] usable
[ 0.000000] reserve setup_data: [mem 0x000000006cf18a58-0x000000006cf19017] usable
[ 0.000000] reserve setup_data: [mem 0x000000006cf19018-0x000000006cf4e457] usable
[ 0.000000] reserve setup_data: [mem 0x000000006cf4e458-0x00000000754b5fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000754b6000-0x0000000076212fff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000076213000-0x0000000076222fff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x0000000076223000-0x0000000077084fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000077085000-0x00000000775a2fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000775a3000-0x00000000775a3fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000775a4000-0x0000000077629fff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000007762a000-0x0000000077ffffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000078000000-0x000000007bffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000080000000-0x000000008fffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed44fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x0000000c7fffffff] usable
[ 0.010345] ACPI: SSDT 0x0000000076D1A2B8 00036D (v01 SataRe SataTabl 00001000 INTL 20120913)
[ 0.010459] NODE_DATA(0) allocated [mem 0xc7fffbc80-0xc7ffffdff]
[ 0.119690] Kernel command line: BOOT_IMAGE=(hd5,gpt4)/bzImage root=PARTUUID=a3ec664e-32ce-4665-95ea-7ae90ce9aa20 rootwait zram.enabled=1 zram.num_devices=3 net.naming-scheme=v250 systemd.machine_id=5c0aa80748604afa81ce94ceeac4b0a6 fsck.repair=yes console=tty1 quiet splash loglevel=3 systemd.show_status=1 rd.udev.log_level=3 net.ifnames=0 biosdevname=0 intel_iommu=on vfio_iommu_type1.allow_unsafe_interrupts=1 thunderbolt.host_reset=false rauc.slot=B
[ 0.301373] MDS: Mitigation: Clear CPU buffers
[ 0.301376] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.374266] MDS CPU bug present and SMT on, data leak possible. See MDS - Microarchitectural Data Sampling — The Linux Kernel documentation for more details.
[ 0.374272] TAA CPU bug present and SMT on, data leak possible. See TAA - TSX Asynchronous Abort — The Linux Kernel documentation for more details.
[ 0.374273] MMIO Stale Data CPU bug present and SMT on, data leak possible. See Processor MMIO Stale Data Vulnerabilities — The Linux Kernel documentation for more details.
[ 0.376434] Memory: 49147636K/50165936K available (20480K kernel code, 2678K rwdata, 7512K rodata, 3308K init, 4260K bss, 1003600K reserved, 0K cma-reserved)
[ 0.396260] raid6: avx2x4 gen() 20257 MB/s
[ 0.413262] raid6: avx2x2 gen() 21959 MB/s
[ 0.430266] raid6: avx2x1 gen() 17367 MB/s
[ 0.430267] raid6: using algorithm avx2x2 gen() 21959 MB/s
[ 0.447271] raid6: … xor() 13023 MB/s, rmw enabled
[ 0.447273] raid6: using avx2x2 recovery algorithm
[ 0.550858] libata version 3.00 loaded.
[ 1.034900] Adaptec aacraid driver 1.2.1[50983]-custom
[ 1.034926] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[ 1.035088] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[ 1.035828] ahci 0000:00:11.4: AHCI vers 0001.0300, 32 command slots, 6 Gbps, SATA mode
[ 1.036794] ata1: SATA max UDMA/133 abar m2048@0xfb719000 port 0xfb719100 irq 38 lpm-pol 4
[ 1.036797] ata2: DUMMY
[ 1.036798] ata3: DUMMY
[ 1.036799] ata4: DUMMY
[ 1.037008] ahci 0000:00:1f.2: AHCI vers 0001.0300, 32 command slots, 6 Gbps, SATA mode
[ 1.043572] ata5: DUMMY
[ 1.043575] ata6: SATA max UDMA/133 abar m2048@0xfb716000 port 0xfb716180 irq 39 lpm-pol 4
[ 1.043577] ata7: SATA max UDMA/133 abar m2048@0xfb716000 port 0xfb716200 irq 39 lpm-pol 4
[ 1.043579] ata8: SATA max UDMA/133 abar m2048@0xfb716000 port 0xfb716280 irq 39 lpm-pol 4
[ 1.043581] ata9: SATA max UDMA/133 abar m2048@0xfb716000 port 0xfb716300 irq 39 lpm-pol 4
[ 1.043582] ata10: DUMMY
[ 1.097028] Btrfs loaded, zoned=no, fsverity=no
[ 1.341568] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.347890] ata1.00: ATA-9: LDLC F6+M.2 480, S0424A0, max UDMA/133
[ 1.349417] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.349494] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.349546] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.349575] ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.350349] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT2._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.350366] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT2._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.350382] ata7.00: ATA-11: ST16000NM000J-2TW103, SN01, max UDMA/133
[ 1.351753] ata1.00: 937703088 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.352508] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT3._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.352524] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT3._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.352540] ata8.00: ATA-11: TOSHIBA MG09ACA18TE, 0104, max UDMA/133
[ 1.352606] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT4._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.352622] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT4._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.352638] ata9.00: ATA-11: TOSHIBA MG09ACA18TE, 4004, max UDMA/133
[ 1.356139] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT1._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.356155] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT1._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.356170] ata6.00: ATA-11: ST16000NT001-3LV101, EN01, max UDMA/133
[ 1.359561] ata8.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.359580] ata9.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.367575] ata1.00: configured for UDMA/133
[ 1.369838] ata9.00: Features: NCQ-prio
[ 1.371226] ata8.00: Features: NCQ-prio
[ 1.372992] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT4._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.373008] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT4._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.374458] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT3._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.374474] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT3._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.377862] scsi 0:0:0:0: Direct-Access ATA LDLC F6+M.2 480 4A0 PQ: 0 ANSI: 5
[ 1.389893] ata9.00: configured for UDMA/133
[ 1.393291] ata8.00: configured for UDMA/133
[ 1.403385] ata7.00: 31251759104 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.403810] ata6.00: 31251759104 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.883717] ata6.00: Features: NCQ-sndrcv
[ 1.884428] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT1._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.884445] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT1._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 1.912007] ata7.00: Features: NCQ-sndrcv
[ 1.912719] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.SAT1.SPT2._GTF.DSSP], AE_NOT_FOUND (20240827/psargs-332)
[ 1.912734] ACPI Error: Aborting method _SB.PCI0.SAT1.SPT2._GTF due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 2.400205] ata6.00: configured for UDMA/133
[ 2.453568] ata7.00: configured for UDMA/133
[ 2.456864] scsi 5:0:0:0: Direct-Access ATA ST16000NT001-3LV EN01 PQ: 0 ANSI: 5
[ 2.530739] scsi 6:0:0:0: Direct-Access ATA ST16000NM000J-2T SN01 PQ: 0 ANSI: 5
[ 2.531308] scsi 7:0:0:0: Direct-Access ATA TOSHIBA MG09ACA1 0104 PQ: 0 ANSI: 5
[ 2.531920] scsi 8:0:0:0: Direct-Access ATA TOSHIBA MG09ACA1 4004 PQ: 0 ANSI: 5
[ 2.571376] md: Waiting for all devices to be available before autodetect
[ 2.571381] md: If you don’t use raid, use raid=noautodetect
[ 2.571385] md: Autodetecting RAID arrays.
[ 2.571387] md: autorun …
[ 2.571389] md: … autorun DONE.
[ 2.578268] Write protecting the kernel read-only data: 28672k
[ 2.578661] Freeing unused kernel image (rodata/data gap) memory: 680K
[ 2.938636] EXT4-fs (nvme0n1p7): mounted filesystem 588bf225-9ccb-482c-a908-85ecfd9c3204 r/w with ordered data mode. Quota mode: none.
[ 5.886147] systemd[1]: systemd 256.17 running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA -SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 +BZIP2 -LZ4 +XZ +ZLIB -ZSTD -BPF_FRAMEWORK +XKBCOMMON -UTMP -SYSVINIT -LIBARCHIVE)
[ 5.886156] systemd[1]: Detected architecture x86-64.
[ 5.888826] systemd[1]: Hostname set to .
[ 5.978659] systemd[1]: /usr/lib/systemd/system/virtstoraged.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtstoraged-sock → /run/libvirt/virtstoraged-sock; please update the unit file accordingly.
[ 5.990031] systemd[1]: /usr/lib/systemd/system/virtstoraged-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtstoraged-sock-ro → /run/libvirt/virtstoraged-sock-ro; please update the unit file accordingly.
[ 5.990327] systemd[1]: /usr/lib/systemd/system/virtstoraged-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtstoraged-admin-sock → /run/libvirt/virtstoraged-admin-sock; please update the unit file accordingly.
[ 5.990638] systemd[1]: /usr/lib/systemd/system/virtsecretd.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtsecretd-sock → /run/libvirt/virtsecretd-sock; please update the unit file accordingly.
[ 5.991139] systemd[1]: /usr/lib/systemd/system/virtsecretd-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtsecretd-sock-ro → /run/libvirt/virtsecretd-sock-ro; please update the unit file accordingly.
[ 5.991432] systemd[1]: /usr/lib/systemd/system/virtsecretd-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtsecretd-admin-sock → /run/libvirt/virtsecretd-admin-sock; please update the unit file accordingly.
[ 5.991739] systemd[1]: /usr/lib/systemd/system/virtqemud.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtqemud-sock → /run/libvirt/virtqemud-sock; please update the unit file accordingly.
[ 5.992283] systemd[1]: /usr/lib/systemd/system/virtqemud-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtqemud-sock-ro → /run/libvirt/virtqemud-sock-ro; please update the unit file accordingly.
[ 5.992593] systemd[1]: /usr/lib/systemd/system/virtqemud-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtqemud-admin-sock → /run/libvirt/virtqemud-admin-sock; please update the unit file accordingly.
[ 5.992888] systemd[1]: /usr/lib/systemd/system/virtproxyd.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/libvirt-sock → /run/libvirt/libvirt-sock; please update the unit file accordingly.
[ 5.993607] systemd[1]: /usr/lib/systemd/system/virtproxyd-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/libvirt-sock-ro → /run/libvirt/libvirt-sock-ro; please update the unit file accordingly.
[ 5.993920] systemd[1]: /usr/lib/systemd/system/virtproxyd-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/libvirt-admin-sock → /run/libvirt/libvirt-admin-sock; please update the unit file accordingly.
[ 5.994181] systemd[1]: /usr/lib/systemd/system/virtnwfilterd.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnwfilterd-sock → /run/libvirt/virtnwfilterd-sock; please update the unit file accordingly.
[ 5.994633] systemd[1]: /usr/lib/systemd/system/virtnwfilterd-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnwfilterd-sock-ro → /run/libvirt/virtnwfilterd-sock-ro; please update the unit file accordingly.
[ 5.994905] systemd[1]: /usr/lib/systemd/system/virtnwfilterd-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnwfilterd-admin-sock → /run/libvirt/virtnwfilterd-admin-sock; please update the unit file accordingly.
[ 5.995168] systemd[1]: /usr/lib/systemd/system/virtnodedevd.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnodedevd-sock → /run/libvirt/virtnodedevd-sock; please update the unit file accordingly.
[ 5.995639] systemd[1]: /usr/lib/systemd/system/virtnodedevd-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnodedevd-sock-ro → /run/libvirt/virtnodedevd-sock-ro; please update the unit file accordingly.
[ 5.995912] systemd[1]: /usr/lib/systemd/system/virtnodedevd-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnodedevd-admin-sock → /run/libvirt/virtnodedevd-admin-sock; please update the unit file accordingly.
[ 5.996170] systemd[1]: /usr/lib/systemd/system/virtnetworkd.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnetworkd-sock → /run/libvirt/virtnetworkd-sock; please update the unit file accordingly.
[ 5.996642] systemd[1]: /usr/lib/systemd/system/virtnetworkd-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnetworkd-sock-ro → /run/libvirt/virtnetworkd-sock-ro; please update the unit file accordingly.
[ 5.996913] systemd[1]: /usr/lib/systemd/system/virtnetworkd-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtnetworkd-admin-sock → /run/libvirt/virtnetworkd-admin-sock; please update the unit file accordingly.
[ 5.997159] systemd[1]: /usr/lib/systemd/system/virtlogd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtlogd-sock → /run/libvirt/virtlogd-sock; please update the unit file accordingly.
[ 5.997862] systemd[1]: /usr/lib/systemd/system/virtlogd-admin.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtlogd-admin-sock → /run/libvirt/virtlogd-admin-sock; please update the unit file accordingly.
[ 5.998106] systemd[1]: /usr/lib/systemd/system/virtlockd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtlockd-sock → /run/libvirt/virtlockd-sock; please update the unit file accordingly.
[ 5.998518] systemd[1]: /usr/lib/systemd/system/virtlockd-admin.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtlockd-admin-sock → /run/libvirt/virtlockd-admin-sock; please update the unit file accordingly.
[ 5.998786] systemd[1]: /usr/lib/systemd/system/virtinterfaced.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtinterfaced-sock → /run/libvirt/virtinterfaced-sock; please update the unit file accordingly.
[ 5.999227] systemd[1]: /usr/lib/systemd/system/virtinterfaced-ro.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtinterfaced-sock-ro → /run/libvirt/virtinterfaced-sock-ro; please update the unit file accordingly.
[ 5.999509] systemd[1]: /usr/lib/systemd/system/virtinterfaced-admin.socket:9: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/virtinterfaced-admin-sock → /run/libvirt/virtinterfaced-admin-sock; please update the unit file accordingly.
[ 6.007562] systemd[1]: /usr/lib/systemd/system/zimaos-user.service:8: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/user-service.pid → /run/casaos/user-service.pid; please update the unit file accordingly.
[ 6.008152] systemd[1]: /usr/lib/systemd/system/zimaos-search.service:7: PIDFile= references a path below legacy directory /var/run/, updating /var/run/zimaos/zimaos-search.pid → /run/zimaos/zimaos-search.pid; please update the unit file accordingly.
[ 6.008384] systemd[1]: /usr/lib/systemd/system/zimaos-message-bus.service:8: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/message-bus.pid → /run/casaos/message-bus.pid; please update the unit file accordingly.
[ 6.008670] systemd[1]: /usr/lib/systemd/system/zimaos-local-storage.service:8: PIDFile= references a path below legacy directory /var/run/, updating /var/run/zimaos/local-storage.pid → /run/zimaos/local-storage.pid; please update the unit file accordingly.
[ 6.009442] systemd[1]: /usr/lib/systemd/system/zimaos-gateway.service:7: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/gateway.pid → /run/casaos/gateway.pid; please update the unit file accordingly.
[ 6.009670] systemd[1]: /usr/lib/systemd/system/zimaos-app-management.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/app-management.pid → /run/casaos/app-management.pid; please update the unit file accordingly.
[ 6.013723] systemd[1]: /usr/lib/systemd/system/winbind.service:8: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
[ 6.017397] systemd[1]: /usr/lib/systemd/system/smb.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[ 6.017605] systemd[1]: /usr/lib/systemd/system/samba-bgqd.service:10: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/samba-bgqd.pid → /run/samba/samba-bgqd.pid; please update the unit file accordingly.
[ 6.020234] systemd[1]: /usr/lib/systemd/system/nmb.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 6.021587] systemd[1]: /usr/lib/systemd/system/icewhale-files.service:7: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/icewhale-files.pid → /run/casaos/icewhale-files.pid; please update the unit file accordingly.
[ 6.021804] systemd[1]: /usr/lib/systemd/system/icewhale-files-backup.service:7: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/icewhale-files-backup.pid → /run/casaos/icewhale-files-backup.pid; please update the unit file accordingly.
[ 6.023749] systemd[1]: /usr/lib/systemd/system/ctdb.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/ctdb/ctdbd.pid → /run/ctdb/ctdbd.pid; please update the unit file accordingly.
[ 6.024656] systemd[1]: /usr/lib/systemd/system/casaos-installer.service:7: PIDFile= references a path below legacy directory /var/run/, updating /var/run/casaos/installer.pid → /run/casaos/installer.pid; please update the unit file accordingly.
[ 6.033066] systemd[1]: /usr/lib/systemd/system/libvirtd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/libvirt-sock → /run/libvirt/libvirt-sock; please update the unit file accordingly.
[ 6.033668] systemd[1]: /usr/lib/systemd/system/libvirtd-ro.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/libvirt-sock-ro → /run/libvirt/libvirt-sock-ro; please update the unit file accordingly.
[ 6.033897] systemd[1]: /usr/lib/systemd/system/libvirtd-admin.socket:7: ListenStream= references a path below legacy directory /var/run/, updating /var/run/libvirt/libvirt-admin-sock → /run/libvirt/libvirt-admin-sock; please update the unit file accordingly.
[ 6.044545] systemd[1]: multi-user.target: Found ordering cycle on getty.target/start
[ 6.044550] systemd[1]: multi-user.target: Found dependency on zimaos-welcome@tty1.service/start
[ 6.044552] systemd[1]: multi-user.target: Found dependency on multi-user.target/start
[ 6.044555] systemd[1]: multi-user.target: Job getty.target/start deleted to break ordering cycle starting with multi-user.target/start
[ 6.045722] systemd[1]: Queued start job for default target Multi-User System.
[ 6.066220] systemd[1]: Unnecessary job was removed for /dev/nvme0n1p7.
[ 6.067507] systemd[1]: Created slice Slice /system/modprobe.
[ 6.068365] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 6.069123] systemd[1]: Created slice Slice /system/systemd-growfs.
[ 6.069905] systemd[1]: Created slice Slice /system/zimaos-welcome.
[ 6.070534] systemd[1]: Created slice User and Session Slice.
[ 6.070885] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.070991] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.071072] systemd[1]: Expecting device /dev/disk/by-label/casaos-boot…
[ 6.071125] systemd[1]: Expecting device /dev/disk/by-label/casaos-data…
[ 6.071165] systemd[1]: Expecting device /dev/disk/by-label/casaos-overlay…
[ 6.071212] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.071263] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 6.071327] systemd[1]: Reached target NFS client services.
[ 6.071377] systemd[1]: Reached target Host and Network Name Lookups.
[ 6.071437] systemd[1]: Reached target Path Units.
[ 6.071675] systemd[1]: Reached target Slice Units.
[ 6.071919] systemd[1]: Reached target Swaps.
[ 6.072177] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.072437] systemd[1]: Reached target libvirt guests shutdown target.
[ 6.076854] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.077528] systemd[1]: Reached target RPC Port Mapper.
[ 6.078749] systemd[1]: Listening on Credential Encryption/Decryption.
[ 6.079605] systemd[1]: Listening on Journal Audit Socket.
[ 6.080267] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.080662] systemd[1]: Listening on Journal Sockets.
[ 6.081434] systemd[1]: Listening on Network Service Netlink Socket.
[ 6.082049] systemd[1]: Listening on udev Control Socket.
[ 6.082377] systemd[1]: Listening on udev Kernel Socket.
[ 6.085524] systemd[1]: Mounting Huge Pages File System…
[ 6.087047] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.088474] systemd[1]: Mounting Kernel Debug File System…
[ 6.089848] systemd[1]: Mounting Kernel Trace File System…
[ 6.091343] systemd[1]: Mounting Temporary Directory /tmp…
[ 6.092181] systemd[1]: var.mount: Directory /var to mount over is not empty, mounting anyway.
[ 6.093038] systemd[1]: Mounting Buildroot /var tmpfs…
[ 6.095375] systemd[1]: Starting Create List of Static Device Nodes…
[ 6.096832] systemd[1]: Starting Load Kernel Module configfs…
[ 6.098286] systemd[1]: Starting Load Kernel Module drm…
[ 6.099708] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 6.101111] systemd[1]: Starting Load Kernel Module fuse…
[ 6.102634] systemd[1]: Starting File System Check on Root Device…
[ 6.105077] systemd[1]: Starting Journal Service…
[ 6.107682] systemd[1]: Starting Load Kernel Modules…
[ 6.109100] systemd[1]: Starting Generate network units from Kernel command line…
[ 6.110593] systemd[1]: Starting Load udev Rules from Credentials…
[ 6.112023] systemd[1]: Starting Coldplug All udev Devices…
[ 6.114882] systemd[1]: Mounted Huge Pages File System.
[ 6.116960] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.118259] systemd[1]: Mounted Kernel Debug File System.
[ 6.118906] systemd[1]: Mounted Kernel Trace File System.
[ 6.119569] systemd[1]: Mounted Temporary Directory /tmp.
[ 6.120222] systemd[1]: Mounted Buildroot /var tmpfs.
[ 6.120729] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.121526] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.121695] systemd[1]: Finished Load Kernel Module configfs.
[ 6.122492] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.122649] systemd[1]: Finished Load Kernel Module drm.
[ 6.123407] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 6.123563] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 6.124299] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 6.124456] systemd[1]: Finished Load Kernel Module fuse.
[ 6.125280] systemd[1]: Finished File System Check on Root Device.
[ 6.126039] systemd[1]: Finished Generate network units from Kernel command line.
[ 6.126858] systemd[1]: Reached target Preparation for Network.
[ 6.128240] systemd[1]: Mounting FUSE Control File System…
[ 6.129650] systemd[1]: Mounting Kernel Configuration File System…
[ 6.131261] systemd[1]: Starting Load AppArmor profiles…
[ 6.132684] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.134088] systemd[1]: Starting Create Static Device Nodes in /dev gracefully…
[ 6.134516] systemd-journald[418]: Collecting audit messages is enabled.
[ 6.135032] systemd[1]: Finished Load udev Rules from Credentials.
[ 6.135807] audit: type=1130 audit(1778913157.838:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-udev-load-credentials comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 6.136848] systemd[1]: Mounted FUSE Control File System.
[ 6.138005] systemd[1]: Mounted Kernel Configuration File System.
[ 6.145110] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.145780] audit: type=1130 audit(1778913157.848:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-remount-fs comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 6.146246] systemd[1]: One time configuration for iscsi.service was skipped because of an unmet condition check (ConditionPathExists=!/etc/iscsi/initiatorname.iscsi).
[ 6.146290] systemd[1]: Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 6.147563] systemd[1]: Starting Load/Save OS Random Seed…
[ 6.158605] systemd[1]: Finished Load/Save OS Random Seed.
[ 6.159283] audit: type=1130 audit(1778913157.861:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-random-seed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 6.173299] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 6.174425] audit: type=1130 audit(1778913157.877:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-tmpfiles-setup-dev-early comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 6.178597] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 6.229464] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.230449] systemd[1]: Reached target Preparation for Local File Systems.
[ 6.233739] systemd[1]: Starting Rule-based Manager for Device Events and Files…
[ 6.299708] systemd[1]: Started Journal Service.
[ 7.419843] EXT4-fs (nvme0n1p8): mounted filesystem fadab15d-e9cc-4bc2-b4af-a2b49a30cbe5 r/w with ordered data mode. Quota mode: none.
[ 7.469179] systemd-journald[418]: Received client request to flush runtime journal.
[ 10.596155] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 10.599459] Adding 8388604k swap on /DATA/.swapfile. Priority:10 extents:64 across:1218314240k SS
[ 12.171366] md: md127 stopped.
[ 12.235504] md: md0 stopped.
[ 12.389912] md: kicking non-fresh sdd from array!
[ 12.412405] md/raid:md0: device sdb operational as raid disk 0
[ 12.412415] md/raid:md0: device sde operational as raid disk 3
[ 12.412418] md/raid:md0: device sdc operational as raid disk 1
[ 12.412908] md/raid:md0: raid level 5 active with 3 out of 4 devices, algorithm 2
[ 12.442734] md0: detected capacity change from 0 to 93754484736
[ 12.527468] BTRFS: device fsid a327f5d4-f069-7380-ae4d-51fab01a4ab2 devid 1 transid 5111 /dev/md0 (9:0) scanned by zimaos-local-st (1024)
[ 12.609676] md: recover of RAID array md0
[ 12.632569] BTRFS info (device md0): first mount of filesystem a327f5d4-f069-7380-ae4d-51fab01a4ab2
[ 12.632584] BTRFS info (device md0): using crc32c (crc32c-intel) checksum algorithm
[ 12.632590] BTRFS info (device md0): using free-space-tree
[ 16.011239] md: md0: recover done.
[ 921.891734] nvme nvme0: using unchecked data buffer
root@ZimaOS:/root ➜ # cat /proc/mdstat
Personalities : [raid6] [raid5] [raid4]
md0 : active raid5 sdd[2] sdb[0] sde[4] sdc[1]
46877242368 blocks super 1.2 level 5, 512k chunk, algorithm 2 [4/4] [UUUU]
bitmap: 0/117 pages [0KB], 65536KB chunk
unused devices:
