ok so i am trying to install twingate on zima os cause the remote network is just not working, i was using twingate on my old casaos but rn i am on zima and i just cant get it to work. is there anyone who can help?
It might be a good idea to try using the remote access feature built into ZimaOS.
Is this helpful?
i have tried to use the build in remote access but its working 1 out of 5 times and mostly i just want to use it for jelyfin to watch stufff, but tailscale is always doing nothing, so i wanted to do twingate but the app from appstore wont open and terminal wont support it, so i tried clouflare but i have to hvae my own domain, which. i will probably get but till then u know how to do via twingate?
You mentioned that Tailscale doesn’t work well. I found that a user recently solved a problem with Tailscale. I wonder if this helps you.
Look forward to your feedback.
sadly that is not working for me, cause i have tailcale installed but it just keeps disconnecting after 5 to 10min so its unusable
Hey, to better help you, we need more info.
Since you mentioned that both the built-in ZeroTier and installed Tailscale/Tailscaled are experiencing connectivity issues, I wanted to check that before the problem, if you’ve made any changes to your network settings, upgraded your network, added a network firewall, set up a VPN or proxy service, switched ISPs, or changed network administrators, etc.
Also, the network configuration and ISP/country or region info may be helpful to locate a possible issues.
