[Tutorial]How to set a static IP address
While it may be obvious to some like myself that have been working with Linux for a while, others it may not be obvious how to set a static IP. So just in case you wanted to know, this is how you can do it from the console.
set a root password in case you have not yet.
At the console, set a root password if you have not done so.
hit alt-f2
login as root
run passwd-root
run the command:
nmcli connection show
You will get an output which looks like this:
Wired connection 1 <UUID> ethernet eth0
zt2oa3epmk <UUID> tun zt2oa3epmk
docker0 <UUID> bridge docker0
virbr0 <UUID> bridge virbr0
run the below commands replacing the IP address with the addresses you want to use:
nmcli con mod “Wired connection 1” ipv4.addresses “192.168.100.100/24”
nmcli con mod “Wired connection 1” ipv4.gateway 192.168.2.1
nmcli con mod “Wired connection 1” ipv4.method manual
systemctl restart NetworkManager
run:
nmcli
to verify the new IP is assigned to the interface.
I usually reboot the system at this point to make sure the change is persistent between reboots.
Thanks you.
Will this survive updates?
Honestly I do not know.
As long as just packages are updated it should, however if the update overwrites the whole OS it may not and you will have to do it again.
No idea what the deal is with this…
Screenshot 2024-07-24 at 10.25.52
I have my router wired into Wired 1 (eth0), so I’m trying to change Wired 2 (eth1) for the NIC adapter.
That’s a strange error…
nmcli device show or just nmcli should show you what the name/device is for eth1
If they are are named eth0 and eth1 you can replace the “Wired connection 2” with eth1
They’re named “Wired connection 1 / 2” on my end as well. And I did try “eth1” in place of that. No idea.
It almost looks like it thinks there’s a character before the W in Wired Connection. You tried eth1 without quotes around it? eth1 I believe would not require the quotes
You could try replacing the double quotes with a single quote.
Unfortunately I have moved on from ZimaOS to TrueNAS Scale so I can’t test it myself right now. If I have time later in the week I can throw ZimaOS on my Zimablade and see if there’s something I can find that way.
The error generates the question mark. Will test without quotes. I think a Zima person said in another thread they’re working to simplify this anyway.
hey, thx for the tutorial, but i am wondering, where you hit “alt + F2” :wink: as it isnt working on the dashboard ^^
connecting via ssh, the root/testonly sitn working as well … mot propably a foolish stupid question :-/
A while ago I went into my router and assigned a static IP to my Cube, and that IP addressed has remained the same ever since. Just thought I’d share in case it might work for others.
I wish they could have made this possible on the web gui instead of going into ssh on the newest update. Newbie with setting up my homeserver lab so any straight forward function thru web gui is appreciated.
Yes, we have already started researching this. We all agree that this feature is very necessary.
Thank you. As a newbie like me in linux, I find CasaOS/ZimaOS very intuitive and straight specially the last update. I know doing CLI/SSH is the way to go but I hope making it on a UI that is just a slide of a button or a menu makes the ZimaOS more appealing.
Thank you very much for your support, we will continue to work hard!
Hello, do you know how to create a bridge? I’ve tried with the nmcli commands but when the pc reboots the bridge doesn’t activate.
your tutorial is correct but the text editor of the community is changing " with “ at the beginning of Wired connection 1 and 192.168.100.100/24 …so if someone wants to make it work he must change “ with " and everything will be ok !
Thanks for sharing this. I have been searching today and finally came across this post. It works well; however, I needed to change the double quotes to single as one of the other members mentioned. Posting this in case someone else has the same issue.
nmcli con mod ‘Wired connection 1’ ipv4.addresses ‘192.168.100.100/24’
nmcli con mod ‘Wired connection 1’ ipv4.gateway 192.168.2.1
nmcli con mod ‘Wired connection 1’ ipv4.method manual
There is a new way:
Just a suggestion for posting a code snippet. Enclose it with ```
Ex:
Good tip.
However, since you can now set it directly in the settings anyway, these commands have become obsolete in the meantime.
