Dear IW,
I and number of pro users are experiencing serious heat problems with the cube under minimal amounts of load.
Example being:
Can we have a response please as your position on this please and possible solutions to reduce?
Dear IW,
Example being:
Hi,there.Let’s try this.
Does your SSD temperature refer to the motherboard or the seventh disk?
individual discs … happens when downloading torrents …
That is the is the temperature of the SSDs on the 7th disc sled.
Sitting - and doing nothing. But 92 C.
This morning it even showed 100 C. What is triggering it?
