2 zimaOS boxes experiencing similar if not same issues with remote login
Why your previous attempts didn’t work
I believe this happened because:
  • Duplicati was first started without a valid SETTINGS_ENCRYPTION_KEY
  • That created an incomplete / invalid settings database
  • Changing env vars afterwards does not fix an already-created DB
  • So the container keeps restarting and the UI shows Service Unavailable
This is normal Duplicati behaviour, not a ZimaOS bug.
The correct fix (safe and simple)
I suggest doing a clean reset of the Duplicati config only and recreating the container once with a proper key.
Step 1 – Stop and remove the container (safe)
This does not delete your backups.
sudo docker rm -f duplicati
Step 2 – Remove ONLY the config database
Safety note:
Do not touch /DATA/Duplicati/backups or your source folders.
Only remove the config folder.
sudo rm -rf /DATA/AppData/duplicati/config/*
This removes the broken settings DB so Duplicati can recreate it cleanly.
Step 3 – Recreate Duplicati with a real encryption key
I suggest using the ZimaOS App UI or CLI, but not both.
If using environment variables, make sure they are exactly:
  • SETTINGS_ENCRYPTION_KEY (no typos)
  • Any non-trivial string (not 1234)
Example (CLI reference):
-e SETTINGS_ENCRYPTION_KEY=ThisIsMyDuplicatiKey123
You can also omit DUPLICATI__DISABLE_DB_ENCRYPTION entirely — the default encrypted DB is fine.
After restart
Once the container starts again:
  • Open http://<zima-ip>:8200
  • The setup wizard should load immediately
  • No more “Service Unavailable”
Extra safety clarification
  • The encryption key is only for the internal settings database
  • It is not your backup password
  • Losing it only affects the UI config, not your backup files
If it still doesn’t come up after that, the next step would simply be:
sudo docker logs duplicati
but I believe this reset will resolve it cleanly.
Thanks, I got in. The log in password is set to some random combination when the docker is created so using the tools and tips you provided above I was able to figure out how to set that.
Thanks much!
Now I just have to figure out how to use duplicati properly haha
Since you asked about using Duplicati properly, here’s a clear, safe way to think about it on ZimaOS.
1) First: how to think about Duplicati (important)
I believe the biggest mental shift is this:
Duplicati is not a file mirror.
It creates an encrypted backup database made of blocks + metadata.
That means:
  • the destination will not look like normal folders
  • restores are done through Duplicati, not by browsing the NAS
  • this is expected and correct behaviour
Once that clicks, Duplicati makes a lot more sense.
2) Recommended NAS backup layout (very important)
I believe most long-term issues come from messy destinations, so I suggest keeping it boring and isolated.
On the NAS (backup destination)
I suggest a layout like this:
/Backups
  /zimaos
    /duplicati
      /data
How to use this in Duplicati:
  • Destination folder:
    /Backups/zimaos/duplicati/data
  • One ZimaOS machine → one Duplicati folder
  • Do not mix multiple machines in the same destination
This avoids database conflicts and restore issues later.
3) What to back up on ZimaOS (and what not to)
I believe this is where many people get into trouble.
Good backup sources (user data only)
I suggest backing up things like:
/media/Zima/Documents
/media/Zima/Photos
/media/Zima/Projects
/media/Zima/Media
Do NOT back up these paths
I strongly suggest not backing up:
/DATA/AppData
/var/lib/docker
/media/ZimaOS-HD
/media/*/.trash
Reason:
  • Docker apps should be re-created, not restored file-by-file
  • Backing up AppData and system paths often causes instability on restore
4) ZimaOS + Duplicati best-practice setup
This is the “template” you can reuse.
One container only
  • Install Duplicati via App Store or CLI, not both
  • One container, one config path
Config location
Do not manually edit files once running.
Destination rules
  • One destination per machine
  • One Duplicati folder per machine
  • Never reuse destinations across devices
Encryption
  • Enable backup encryption
  • Store the password securely
  • Losing it = backups unrecoverable
    (This is separate from the UI password and settings DB key.)
5) Sensible default settings
I suggest starting with:
  • Backup type: Incremental
  • Compression: On
  • Volume size: 50–100 MB
  • Schedule: Daily
  • Retention: Keep all backups (refine later)
Avoid aggressive cleanup or “smart” retention until you’re confident.
6) Test restores early (non-negotiable)
I believe this is the most important rule:
  • Restore a single file
  • Restore a whole folder
  • Do it early, not “one day”
A backup that hasn’t been restored is unproven.
7) Extra safety notes
  • Don’t mix UI and CLI workflows
  • Don’t manually delete files inside the Duplicati config folder
  • Keep Duplicati isolated from Docker/AppData backups
  • Watch warnings in logs, not just green ticks
One-line takeaway
I believe Duplicati works best on ZimaOS when you keep sources clean, destinations isolated, treat it as a backup database (not a file mirror), and test restores early.
Ideally, I’d like duplicati to back up to the WD mycloud on the same network, but I’ve having trouble connecting to it in duplicati through webdav or ftp / sftp. This I believe is more an issue with the WD but not 100% certain.
I should be able to mount 192.168.0.81 again, but if not mistaken that will add it to /media and then I might have the same issue with space correct? Also, would I need to mount the drive in case of reboot or powerfailure?
