ZVM console does not load when accessing ZimaOS through WAN/domain
Hello,
I can access my ZimaOS server normally when I connect through the local network IP address or through Tailscale. In both cases, ZVM and the virtual machines work without any issues.
However, when I access ZimaOS remotely using my domain name / WAN IP address, I can log in to the ZimaOS WebUI normally. I can open the ZVM application and select a virtual machine, but the VM console never displays an image. It remains stuck on the loading dots indefinitely.
The issue only affects the virtual-machine console when using remote WAN/domain access. The ZimaOS WebUI itself works correctly.
Is there a specific port, reverse-proxy setting, WebSocket configuration, or other network requirement needed for ZVM console access through a domain name/WAN connection?
Thank you.
