I had using the (ZimaOS v1.4.1) ZVM to install win11 and Zorin-OS-17.3-Core-64-bit-r2. When I run vm via localhost ip is work (eg 192.168.1.2), but when I access the device via cloudflare tunnel the ZVM is blackscreen and keep loading…
I had tried Bridge to eth0 / eth1 is same.
It’s setting issues?
thanks for reply.
Has anyone found a solution? As my friend mentioned, so far I haven’t been able to access my ZVM through the Cloudflare tunnel. That would be very practical.
