I installed ZimaOS 1.0 on the NAS of Intel N6005.
If a shutdown is performed on the ZimaOS system, the NAS will be powered off directly, and the system exit status will not be visible on the monitoring screen of the NAS.
However, if the NAS power button is pressed directly, system exit is normal, and the exit status of the system software can be seen on the monitoring screen, rather than simply powering off.
