Zimaos with a second big hardrive won't use it for media
I have a zimaos installation which has a small drive for the system and a much larger drive for files. The problem I am running into is that I can’t get my media folder to be on the larger drive.
The system drive is ZimaOS-HD/Media/Movies and movies moved here get picked up by Jelly fin
The big drive is /HDD-Storage-20tb/Media/Movies
In Jelly fin these are the mounts. Any help greatly appreciated.
you need to use this path: /media/HDD-Storage-20tb/Media
Thank you. That solved a problem that has bugged me for months. Knowing the answer let me quickly figure out how I should have known that. Funny how you can miss something so easy.
no problem, hope you enjoy the time!
