Hallo
after Update, may Apps have a high memory usage then before.
My Device Info is:
Intel(R) Celeron(R) G4900T CPU @ 2.90GHz
2 Cores2.90 GHz2 Threads
1 RAM 8 GB total
2667 MHzDDR4
GPU
Intel CoffeeLake-S GT1 [UHD Graphics 610]
Hallo
My Device Info is:
1 RAM 8 GB total
2667 MHzDDR4
GPU
Yep, seen this on ZimaOS v1.6.0-beta2, especially on 8GB systems.
Likely causes:
Quick checks:
docker stats
free -h
If it stays high after a few hours uptime, check which container is using it — that’s usually the trigger.
Worth reporting while it’s still beta.
