Hallo
after installing the beta version my fieles app is useless and looks like this:
System is a lenovo thinkcentre m920q with celeron processor
This is a ZimaOS beta Files app bug, not a disk or RAID issue.
Your storage is still mounted, but the Files UI can’t enumerate it, so folders appear empty/grey and unusable. This commonly happens after a beta upgrade and affects the Files app’s index/metadata layer.
Not hardware, not CPU, not data loss.
Fix options:
Reboots or browser changes won’t fix it.
I found out that this is a problem with the firefox browser.
After I delete the cache the problem was solved.
thx for helping.
JBOD being greyed out is expected in 1.5.4-beta1.
JBOD is not implemented yet in ZimaOS (it’s marked Coming soon), so no released version currently supports JBOD, downgrading won’t enable it.
If you need non-RAID behavior right now, the only options are:
Best to stay on stable/beta and wait for official JBOD support.
