ZimaOS v1.3.2-beta2 Raid problem
I’m having trouble doing Raid on ZimaOS v1.3.2-beta2. Migrating location doesn’t seem to work. Please fix the errors, sir.
If you can explain your operation and your hardware device in detail, as well as accompany the screen recording or screenshot, this will help us solve the problem faster.
My PC is ThinkCentre M93/M93p 4th Generation Intel Core i5-4670 4 / 4 3.4 GHz / 3.8 GHz 6 MB 8GBDDR3-1600 HD 4600. I have two 512GB SSDs installed as external drives in USB 3.0. I want to use these two drives as RAID1. In the storage tab in the settings, it doesn’t work to set up RAID1.
Add images
Thank you for sharing. Regarding the case of RAID with USB devices, we found that USB devices may have some instability, which may affect the performance and reliability of the RAID. In order to get better stability, we recommend using SATA devices to form a RAID, if you have the condition to change to SATA devices, you may get a better experience.
Thank you very much.
