ZimaOS - SMB shares not listed in clients (Explorer, etc)
Hello,
I am testing ZimaOS as a candidate for my new NAS setup. I have created several shares on a disk, made them public, with guest access on. If I connect to them directly without authentication (e.g. \\server\share) they work ok, as I wanted to, no problem. However, when I browse from Windows Explorer (Network/ZIMAOS) the shares are not listed (enumerated) on the server (on \\server) as they should for a public access scenario (with no authentication). The servers always returns an empty list. This is critical for my setup, I currently use a QNAP NAS that works fine in this respect and my entire local ecosystem depends on this. I know the security issues, they do not apply to my config as the network is purely local and trusted.
Is there a way to correct this? As a temporary measure, is there a way to add this feature by editing the /etc/samba/smb.conf and associated files?
Thanks a lot,
Dan
I had a problem with these shares too on Windows and it is very sensitive in what name you are using. I have gone to Codex and did it all with AI where they do all kind of things with commands in PowerShell to check which shares are visible, etc. What are connected, etc so dive into AI and make your shares okay it took me a day or so to have a number of shares corrected because windows is very peculiar in having shares coupled to accounts or not accounts if there is a 1 hanging around that is not quite stopped or coupled to another name. Try using AI. I used Codex and chat with it.
