ZimaOS - slow smb transfers using Tailscale
I have a problem with ZimaOS and sharing files via SMB using tailscale in Docker. When I try to download a file via SMB from my Zimaos, the transfer speed is 700 kb/s and the download often stops. I checked ipref3 and the speed via tailscale is about 7 MB/s, I have the same speeds when I try to download the same file via smb but shared from another server with Debian and CasaOS.
Tests have shown that the problem is smb with tailscale in winter because neither smb after lashing nor taiscale speed are a problem separately, they only cause problems together.
Is there any solution to this problem?
