Hi all
Have zima os installed on small form factor intel nuc pc works great except for writing to the usb hard drives…it keeps saying read only access error.
I can pull files from zima to pc over lan network no problem but writing files back to the shared folder on zima os is not working.
i don’t see any way to fix this with limited shh ability of zimaos
Currently on 1.2.3 we found that ntfs format usb devices will have problems writing, you can check if your hard disk is utfs, we will deal with it on 1.2.4.
Many thanks…i reformatted to EXFAT and can now write over network to drives and read without further issues
Look forward to version 1.2.4
