ZimaOS Open Beta 0.4.9!
Dear ZimaOS Users,
We are delighted to announce the release of the latest version of ZimaOS, version 0.4.9! You can update using either of the following methods:
  1. Reinstall version 0.4.9: You can download and reinstall version 0.4.9 by clicking on the following Github link
  2. Click the update button in the top left corner: You can also update to version 0.4.9 by clicking the update button located in the top left corner of the interface.
V0.4.9 Update Log:
Fixed
  • Fixed the issue where the server connection would cause the Zima client (Windows version) to crash.
  • Blocked the display of the optical drive in the disk.
  • Fixed the issue where the server connection would fail if the assigned network segment and gateway were not in the same range, resulting in the inability to allocate a network ID.
  • Fixed the problem where Samba was mounted but lacked access permission.
  • Addressed display adaptation issues on the mobile end.
  • Optimized OTA updates.
We strongly recommend updating to version 0.4.9 for a more stable and efficient ZimaOS experience.
ZimaOS Open for Testing! We Need Your Feedback!
To ensure that ZimaOS meets the highest standards of performance, security, and user-friendliness, we are opening ZimaOS for testing! As a very first user, you’ll have the unique opportunity to be among the first to experience ZimaOS before its official release. Your valuable suggestions and feedback will directly shape our final product.
Any issue or comments are welcome. Feel free to post ZimaOS topic on IceWhale forum. Remember to choose tag’ zimaos open testing’.
Post Issue on forum (sample):
Describe the bug
A clear and concise description of what the bug is.
Screenshots
If applicable, add screenshots to help explain your problem.
Other feedbacks
Join ZimaOS Open Test Partner Team
If you have further interest of ZimaOS, we have Partner Plan that is recruiting 50 test specialists to explore the depthsof ZimaOS’s beta features.
Yes we are recruiting 50 test specialists from our community! As a test specialist, you’ll be among the first to experience beta functionality before general release. You’ll also have more granular control and expanded permissions to thoroughly test all aspects of ZimaOS.
Please take a moment to fill out this form to express your interest. We will follow up with next steps via Discord or email after receiving your completed form. Let’s get hands-on with ZimaOS early and directly influence the product through your findings. Your real-world testing and usage will help ensure ZimaOS delivers an outstanding experience in its final release.
If you encounter any issues or have any suggestions during usage, please feel free to contact our support team. Thank you for your continued support!
ZimaOS Open Beta Demo
Wishing you a delightful ZimaOS Open Beta experience!
Best Regards,
ZimaOS Team
