ZimaOS not recognizing an active mdadm rebuild in progress
To start, this is not the end of the world. I had a drive failure, shutdown, replaced the drive, restarted and added the new drive to the raid at the command line using mdadm. The rebuild is proceeding normally.
I’m using ZimaOS 1.5 in both cases describe here.
However, in the past when I had a failure, and the ZimaOS interface showed my storage rebuilding and available, with a % indicator and an ETA. This time, it is still telling me I have a degraded raid with a drive unavailable, even though the rebuild is ongoing. I have tried looking for a refresh function, restarted zimaos at the command line, but I can’t get it to recognize current events. Any suggestions?
Thanks in advance.
OK the mdadm rebuild completed, my raid is intact, yet Zima is still indicating that I have a new drive to add and that my raid is failing. I am still in read-only mode, this is becoming a problem. Suggestions?
Hi, to help others understand and respond quickly, please fill out the template below.
Description
Explain what’s happening in simple terms.
Steps to Reproduce
List the exact steps that lead to the issue.
(Screenshots are helpful, videos or screen recordings are even better.)
Expected vs Actual Behavior (optional)
What you expected to happen, and what actually happened.
Before It Happened
Mention any changes or actions performed before the issue appeared.
Troubleshooting Tried
Describe what you’ve already done to fix it.
(Include visuals if possible.)
System Details
Add your hardware specs, ZimaOS version, Zima client version, and Client OS version.
You are suggested to make this permanent: Preferences > Profile > About Me. Recommended format:
ZimaCube | N150 | 64GB | 990 Pro | RTX 2000 | ZimaOS 1.5.1
Thank you for taking the time to include these details, and it helps everyone resolve issues faster and keeps the community running smoothly.
