ZimaOS+ lost after ZimaBoard2 boot up?
Hello,
after booting up a ZimaBoard2 unit, which was shut down yesterday, the ZimaOS dashboard displays it as if the ZimaOS+ is lost / somehow not detected. Although Zima hardware have the ZimaOS+ included by default (vs. installing ZimaOS on non-Zima hardware, where ZimaOS+ can be licensed in addition).
When clicking on “Device info” the infos are also empty. Anyone knows what is going on here?
Thanks for information and how to fix this permanently.
After a shutdown and boot up again of the ZimaBoard2, it now shows again the correct device info and ZimaOS+ status.
While the ZimaBoard2 was in that previous system condition, I noticed also the following malfunctioning:
  • btop was not opening up (tried to invoke the usual function from the ZimaOS dashboard from the System widget). There was simply nothing happening at all.
  • System reboot as well as shutdown - when trying to do via top left corner icon, which opens up the “General” window and displays then bottom left corner the options for shutdown and restart - also didn’t work at all from the dashboard. I only got it to shutdown via an ssh session.
What is the reason for the ZimaBoard2 / ZimaOS behaving like that as depicted?
Please contact support@icewhale.org and we will be happy to assist you!
Hello, thanks. It disappeared after a system restart.
If it will happen again, I’ll follow your advice to send support an email with a link to this discussion.
It would be good though if issues like that - once considered reviewed here - are captured in Zima’s internal bug tracking system and handled accordingly. Optimally a short note on its severity and first assessment with regards to the root cause in response, but that might be wishful thinking :slightly_smiling_face:
Excellent suggestions and ideas. We are very grateful for every user’s thoughts and feedback.
