Zimaos.local not working (beta 1.6.2)
After the latest beta update, I can no longer connect to the interface via HTTPS using zimaos.local. I can connect using my internal IP address.
Thanks for your feedback. We will fix this issue in the next version
Do you have a TimeMachine share enabled?
If yes it’s probably the same Issue I have since 1.6.0 Beta: Avahi crash with 1.6.0 beta 2 and TimeMachine share
