hello im running zimaos and in the appstore i downloaded jellyfin and plex in a lincstation n1 nas. the issue im running is cpu is way high almost 100% when i do 2k or 4k videos is there a way to fix this? move it to ram or something else thanks. @777-Spider
I had a problem with Jellyfin’s excessive RAM and CPU usage caused by an automatic function. Specifically it was the automatic volume normalisation task which, once started, doubled my system’s resource consumption. In any case, I’m sure your problem may have something in common with mine…
