Zimaos beta 1.70 beta 2 ssh
while trying to access web base terminal i get this error from firefox v153
Secure Connection Failed
An error occurred during a connection to 192.168.1.166:7681. SSL received a record that exceeded the maximum permissible length.
only option is go back or Advanced i get this when i select advance
What makes the site look dangerous?
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
What can you do about it?
Please contact the website owners to inform them of this problem.
Learn more about secure connection failures
Error Code: SSH_ERROR_RX_RECORD_TOO_LONG
don’t know what this means but i cannot access web terminal please help
@dreadylock58 Have you turned on https or see if the address bar is https://192.168.1.166:7681? If so, try to change it to http access. It seems that it has nothing to do with ssh. It may be an ssl certificate problem.
i turned off https and it worked now can i change it’s ip and turn backon https
thanks in advance
You need to configure a valid SSL certificate.
I remove https then rebooted and restore https i get tis message no more thanks for all the help
