With apps such as qBitorrent, Jellyfin, Plex installed on main storage (volume) of ZimaOS, is it possible to configure the:
“download path” of qBittorrent;
the libraries (Movies, TV Shows) path of Plex and Jellyfin;
to another volume of ZimaOS (not a share on LAN) or the only way is to migrate the “App Data” to the desired ZimaOS volume?? Any ideas about the best way to do it?
Hello… Thank you for your answer but it doesn´t work… I think it has to do with permissions… For what i can understand even if i migrate the data to another volume, the paths for those apps must be inside the path: “/DATA/AppData/…” can anyone confirm this?
I had this issue too. To fix it (BTW I’m not on a ZimaCube. I’m using the Aoostar WRT pro).
Locations in ZimaOs are in /media/sdxX [/sdxX you must change to your drive]
for example, My Download is in another hhd “/sda1/Download” so I’d add my “Download” folder to the compose (in volumes) by writting
" - /media/sda1/Downloads:/Downloads #Download Folder " (delete quotations )
