ZimaOS 1.4.2-beta - Shut down Add drive
When telling to shut down PC the Beta 2 closes off the Apps with red warning at top and doesn’t shut down as 1.4.0
Adding a drive in storage is showing Add drive - open Add drive tab and no drive there to add. Sometimes the drive id dropped on reboot and need to be reenabled. sda in Pci-e slot old Marvell RAID MSATA card, ran 2x in 1.4.0 no issues
Hi, to make the team better help you locate the issues, please follow up and fill in the problem-report template.
To do this, just open a new post here:
https://community.zimaspace.com/new-topic?category_id=33&tags=problem-opened
Would you?
