ZimaOS 1.4.0 CPU bug
You are welcome. The 6% in a CPU with 1.1 GHz will be 2% in a CPU with 3 GHz, which is not considered high in a normal CPU. Anyway, thanks for your detailed feedback and keep it happening. We will continue improving the performance of the system.
Thank you for clarifying that those CPU peaks are not critical. Could adding a configurable refresh interval (e.g., 1s to 10s) in the Widget Settings be a solution to create a smoother display, avoiding second-by-second value updates?
Additionally, I’m still observing constant localhost traffic (~10 kB/s upload, ~6 kB/s download) on eth0, also not displayed in the network widget prior to version 1.4.0. Using ntopng, I identified frequent dashboard API calls (e.g., /v1/container/usage) as the source.
When the refresh interval are shorten and the rate are highten, it will increase CPU load. So it is a work of balancing.
Please keep these feedbacks happen. And images and videos are preferred instead of the text description.
