Hi there
I have the ZimaCube non Pro and I am using Unraid on it. The usb drive needs to be setup on a USB 2.0 port. Which ports are 2.0 and which are 3.0?
Hi there
The front seems OK in my case.
@777-Spider do you know? I’m using ZimaCube for Unraid and the recommendation is to use USB 2.0 ports for the usb drive. The ZimaCube has 2 USB 2.0 and 4 USB 3.x ports but the documentation and manuals don’t specify which ones are 2.0.
Hi
for ZimaCube
the front panel is USB 3, and back panel is USB 2;
for ZimaCube Pro
All ports are USB 3;
Probably a USB 2 drive will work?
I have heard of people using the usb that is located on the motherboard. It is being used as a wireless connection for the 7th bay that holds the 4 SSDs. It can be removed to use for Unraid.
Not sure if it is usb 2.0 or 3.0.
