ZimaCube TrueNAS Installation Guide
Hardware environment:
1× ZimaCube N100 prototype V2.0
1× Monitor
1× DP
1× Keyboard
1× Ethernet cable 1 X USB flash drive (as installation disk)
Brief description of quick operation process:
Download the TrueNAS.iso image file and use Rufus to write this file to a USB flash drive as an installation disk.
Insert the installation disk into the ZimaCube N100 prototype V2.0 and pull it out after the installation is complete.
Restart ZimaCube N100 prototype V2.0
Log in and use TrueNAS
Detailed installation process
Step1: Download the image file
Click on the official link below:
Step2: Make an installation USB disk
Use Rufus, select the USB disk device and add the iso file;
Step3: Install TrueNas on ZimaCube N100 prototype V2.0
Select eMMC installation
Set password
Installation succeeded
Reboot ZimaCube N100 prototype V2.0
Step4: Read the IP and access TrueNas
Account: admin Password: casaos
Now you can use TrueNAS in ZimaCube N100 prototype V2.0!
Does this need to be installed before a RAID is set up? Or could it be installed after creating a RAID in ZimaOS, and the RAID will continue to function? NAS stuff is all very new to me and I want to make sure I’m handling it right.
Two different OS’ and Truenas uses ZFS… so very different… would need to re-create the pool… that being said I have Truenas running on a Zimablade and it is working well
Any distinct reasons for why you went with TrueNAS?
I like ZimaOS, I also know it’s still in development, and I’m wondering if there are benefits with TrueNAS by comparison.
I had planned to get my Cube and use it since day 1, but now it feels daunting having to make permanent decisions…
mainly because I have been using Truenas for a while now and it works really well… Proven OS for what I am doing… NAS server, Jellyfin and Plex… and Tailscale access… Lots of apps to add to it… active forums for support… price is right
