Good afternoon
I’m having difficulty getting CPU temps to appear in unRAID. Anyone managed to get it workin with a Pro?
There may be several reasons:
- Your Unraid may need to be updated;
- The CPU temps sensing function of the Unraid system does not yet support the CPU of Zimacube Pro;
- How was your Unraid installed? Was it installed directly or in a virtual machine?
- Other reasons;
Would you please provide your Unraid version so that we can further troubleshoot the problem?
Hello.
Yes that’s my assumption too that there needs to be a driver creater to allow UnRAID to read the temp.
I’ve installed UnRAID 6.12.10 via a flash USB (not Vm)
Hi, we also tested the same version of unraid, but did not find the built-in temperature monitoring function of the system. Did you implement CPU temperature monitoring by installing a plug-in? Or, your method may be from community’s app solution. See this:
If so, as far as we know, the plug-in/app’s support for CPUs is not always up to date, and you may need to contact the plug-in/app’s author to find out the supported models.
If not, please provide your method for implementing temperature monitoring.
Thank you
It works for me straight away. Install plugin → Detect → reboot → … → Select Temp
im on Unraid 7.0.0. beta 2
I’m still on unraid 6, but one update higher than OP and have no issues.
