ZimaCube HDD Installation
Hi,
When I was installing my first HDD (seagate 20TB) into the ZimaCube HDD bays. I found and issue that the ZimaCube failed to boot up (stuck at the BIOS EFI error like following picture) if I installed the disk in the most left bay (i.e. the one far away from the 7th SSD bay). Then I tried to put it into the most right one (the one next to the 7th. bay), it booted up sucessfully.
So is there a specific order that I should follow when I install the HDD? From the most right bay to the left one by one?
Thanks.
Same error after installing proxmox and I saw that also happens with Unraid.
Did you found a solution?
Thanks.
No. I just put it into the most right one (the one next to the 7th. bay) and no such error seen.
