Greetings,
My ZimaCube (base model, not pro) has already had the cooling fan upgrade. However, periodically my fan will go into a surge mode.
My CPU ramps up to about 18% and the fan kicks in for 4-5 seconds, then both CPU and fan drop down to about 4% for a few seconds then it ramps up again.
This will last for minutes or hours then things will revert to normal operations.
It can happen at all hours of a day, with little to no changes on the ZimaCube. I am not torrenting files or anything like that that might cause some change in demand/load.
Monitoring the CPU list of what’s running does not seem to indicate what might be causing this.
Here is a list of what I have installed.
big-bear-portainer
big-bear-tailscale
anythingllm
homepage
big-bear-beszel
big-bear-brave
qbittorrent
openspeedtest
jellyfin
duplicati
syncthing
big-bear-openvpn-as
sabnzbd
uptime-kuma
big-bear-myspeed-app-1
ttydbridge
Any assistance helps.
