Zimacube 2 is only stable if maximum cpu state is capped to C6
As in the title. I recently purchased a Zimacube 2 (upgrading from a Zimaboard 2, which was rock solid). I plugged the NVME which was already in the Zimaboard 2 (ZimaOS 1.8.0) and configured the few settings that needed some adaptation. However, shortly after using the ZimacCube 2, I started to experience random crashed, often no more than 15-20 minutes after boot, with no clear traces in the log. The system would completely halt, frozen and everything would go down, including the network (the zimacube 2 would not be visible anymore on my router).
After multiple attempts and also with the support of AI, I identified the problem in the CPU going too low with the voltage due to the deeper power states; after capping the maximum cpu state to c6, my system seems to be finally stable.
I wanted to report this in case someone had the same experience and to check if is a known issues. Not sure if it will be addressed in a future bios update or not, but it was the only way to make my system usable. On the other hand, it is disappointing to not fully use a power saving feature for a device that is supposed to be 24/7.
Thanks
Please email to support@icewhale.org
