Zimaboard2 pinout
Hi, I’m developing an enclosure for Zimaboard2. I want to put a power button and Hdd led’s. I did not find anything about the panel I/O. Is the same layout as Zimaboard1?
Hi, i;m just investigating exactly that, probably you already did, but this is the pinout of the 1664 which is a bit different of the 832
looking from behind (where the battery is) PCI-E is at the bottom, video display port is on top
you have two rows of pins to the left total 14 pins (2x 7)
   GND    X    X  ??
   +5V    X    X  ??
    ??    X    X  ??
   PWR   |X    X| RESET
  SWITCH |X    X| SWITCH
  HDD-??  X    X  PWR LED -
  HDD+??  X    X  PWR LED +
HDD output does not work, for some reason
the + is connected to +5V though 330ohms but the HDD- is floating at 1V
and it shows no activity :(
