ZimaBoard 2 PCIe Slot Link Width: Stuck at x2 despite x4 marketing?
Hi everyone,
I am having trouble getting my M.2 NVMe SSD to run at its full potential on the ZimaBoard 2. Even though the board is marketed with a PCIe x4 slot, my drive is only ever running on 2 lanes.
The drive is a WD Black SN770. I tried the included M.2 adapter as well as another one from Amazon, both connected directly to the PCIe port without the riser cable.
Here is the lspci output:
$ sudo lspci -vvv -s 04:00.0
04:00.0 Non-Volatile memory controller: Sandisk Corp WD SN560/SN740/SN770/SN5000 NVMe SSD (rev 01) (prog-if 02 [NVM Express])
        Subsystem: Sandisk Corp WD SN560/SN740/SN770/SN5000 NVMe SSD
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 16
        Region 0: Memory at 80a00000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [80] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [90] MSI: Enable- Count=1/32 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [b0] MSI-X: Enable+ Count=65 Masked-
                Vector table: BAR=0 offset=00003000
                PBA: BAR=0 offset=00002000
        Capabilities: [c0] Express (v2) Endpoint, IntMsgNum 0
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W TEE-IO-
                DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 16GT/s, Width x4, ASPM L1, Exit Latency L1 <8us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes, LnkDisable- CommClk+
                        ExtSynch+ ClockPM- AutWidDis- BWInt- AutBWInt- FltModeDis-
                LnkSta: Speed 8GT/s (downgraded), Width x2 (downgraded)
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range B, TimeoutDis+ NROPrPrP- LTR+
                         10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
                         AtomicOpsCtl: ReqEn-
                         IDOReq- IDOCompl- LTR+ EmergencyPowerReductionReq-
                         10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
                LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
                LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
                         EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported, FltMode-
        Capabilities: [100 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
                        ECRC- UnsupReq- ACSViol- UncorrIntErr- BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
                        PoisonTLPBlocked- DMWrReqBlocked- IDECheck- MisIDETLP- PCRC_CHECK- TLPXlatBlocked-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
                        ECRC- UnsupReq- ACSViol- UncorrIntErr+ BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr- CorrIntErr- HeaderOF-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+ CorrIntErr+ HeaderOF+
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [1b8 v1] Latency Tolerance Reporting
                Max snoop latency: 3145728ns
                Max no snoop latency: 3145728ns
        Capabilities: [300 v1] Secondary PCI Express
                LnkCtl3: LnkEquIntrruptEn- PerformEqu-
                LaneErrStat: 0
        Capabilities: [900 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1- L1_PM_Substates+
                          PortCommonModeRestoreTime=32us PortTPowerOnTime=10us
                L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1-
                           T_CommonMode=0us LTR1.2_Threshold=90112ns
                L1SubCtl2: T_PwrOn=44us
        Capabilities: [910 v1] Data Link Feature <?>
        Capabilities: [920 v1] Lane Margining at the Receiver
                PortCap: Uses Driver+
                PortSta: MargReady- MargSoftReady+
        Capabilities: [9c0 v1] Physical Layer 16.0 GT/s
                Phy16Sta: EquComplete- EquPhase1- EquPhase2- EquPhase3- LinkEquRequest-
        Kernel driver in use: nvme
        Kernel modules: nvme
Is this x2 limitation exptected behaviour, or is there a BIOS toggle I am missing?
Hello!
Regarding the PCIe slot configuration of the ZimaBoard 2, there is an important technical detail to clarify:
The PCIe slot on the ZimaBoard 2 retains the same x4 open-ended connector form factor as the previous generation, allowing it to physically accommodate x4 and larger expansion cards. However, in terms of electrical wiring and signal lane allocation, it is designed as x2. This means its maximum negotiated link width is x2, rather than being limited by software or firmware.
This was a deliberate trade-off decision made during the hardware design phase. The reason lies in the relatively limited number of available PCIe lanes provided by the Intel N150 platform used in the ZimaBoard 2. To ensure sufficient bandwidth for other high-speed interfaces, such as the 2.5GbE NIC and USB 3.1 (10Gbps), we had to allocate the PCIe lanes judiciously. As a result, some of the lanes were assigned to these critical interfaces.
Despite the x2 configuration, this PCIe interface still offers a theoretical peak bandwidth of approximately 1.9 GB/s. This bandwidth is generally ample for most common expansion needs, such as:
  • Installing a dual-port 10GbE network card
  • Adding 3–4 additional SATA 3.0 ports via an adapter card
  • Running a high-performance NVMe SSD (while it may not fully utilize the drive’s maximum x4 sequential speeds, its performance still far exceeds that of SATA SSDs and meets the demands of many real-world use cases)
Therefore, the behavior you are experiencing is not a malfunction but rather a defined hardware specification of this model. Although it may be disappointing for users seeking the ultimate SSD sequential read/write performance, this design ensures a balanced and practical allocation of resources across the board’s various high-speed interfaces.
We hope this explanation helps clarify the reasoning behind the design.
