Zimaboard 2 - GPU stop my zimaboard to work
Hi everyone,
I recently switched my GPU from my pc to a newer one so I decided to mount the old one to the zimaboard 2.
My GPU is a Zotac Nvidia GTX 1660.
I initially mount the GPU on the external docking GPU that I bought as an add-on from the zimaboard.
Then I followed instructions from another topic
cd /var/lib/extensions/
wget https://github.com/jerrykuku/staff/releases/download/v0.1.3/nvidia-open-kernel-580.105.08-linux-6.12.25.raw -O nvidia-open-kernel-580.105.08-linux-6.12.25.raw
systemd-sysext refresh
install-nvidia-kernel-open
but zimaboard seems to not recognize my GPU.
Also with nvidia-smi command I received the error NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I decided to try my last idea:
I removed the external docking and connected the GPU directly to my zimaboard.
After that when the GPU is mounted on the zimaboard, I cannot reach my zimaboard via ssh (I’m using the zimaboard only via ssh or web browser).
I don’t know how to proceed or what log I could check to understand this issue.
Could you help me please?
I’m a newbie on linux and operating system so if I need to provide more info please tell me where to get the infos.
ZimaOS version is 1.4.3
Thank you all.
Your Nvidia GTX 1660 doesn’t need that driver; it’s intended for the 50-series graphics cards. You need to uninstall it and use the system’s default driver instead.
Hi, I had the same error message as Aixel402 when I run the nvidia-smi command.
How to you install any Nvidia drivers installed by mistake and return to the system’s default driver.
Many thanks for any help.
Gavin Baker.
Hi,
Thank you Jerry for your first feedback,
as suggested I uninstalled it with uninstall-nvidia-kernel-open command but connecting the GPU still does not work.
What should I do?
If I should try to connect monitor and keyboard to the zimaboard, should I put the hdmi cable on the GPU or the zimaboard port?
Thank you
A GTX 1660 should normally work fine on the ZimaBoard 2, but a few things here stand out.
First, Jerry is correct, the nvidia-open-kernel-580.105.08 sysext was only for newer NVIDIA cards and was not needed for the GTX 1660. Good that you already removed it.
The bigger issue is this part:
“when the GPU is mounted directly to the ZimaBoard, I cannot reach it via SSH”
That points more towards either:
  • power delivery issue,
  • PCIe/riser compatibility,
  • or the system hanging very early during boot.
A GTX 1660 draws much more power than low-profile cards people usually test with ZimaBoard 2. If the external dock or PSU is unstable, the board can lock up during initialization.
At this stage I would avoid installing more drivers until basic hardware detection is confirmed first.
I would suggest:
  1. Connect a monitor and keyboard directly to the ZimaBoard.
  2. Leave the HDMI connected to the ZimaBoard HDMI port first, not the GPU.
  3. Boot the system and see if:
    • ZimaOS fully boots,
    • screen freezes,
    • or kernel errors appear.
Once booted, check whether the GPU is even detected:
lspci | grep -i nvidia
Also check:
dmesg | grep -i nvrm
and:
dmesg | grep -i pci
Post the results back here.
One more important thing:
ZimaOS 1.4.3 is quite old now. GPU support and PCIe handling improved a lot in newer releases, so this could also be related to the older kernel in 1.4.3.
