ZimaBlade Power Issue Solutions
Thank you for your interest in the ZimaBlade power supply. We quickly did some research and compatibility testing and came up with the following recommendations:
  1. A PD power supply with 45W or more that supports 12V3A, or a laptop power supply you already have at home, can drive the ZimaBlade.
    https://www.amazon.com/UGREEN-Charger-2-Pack-3-3FT-Cable/dp/B0BN7VZY97
  2. If your monitor supports PD power supply and one-line display, the ZimaBlade can be directly connected to your monitor and work through the Type-C port for display output.
  3. For long-term use, consumer-grade PD power supplies are not so suitable for server scenarios based on our research. Therefore, ZimaBlade still comes with an official standard power supply.
    12V/3A Power Adapter for ZimaBlade – Zima Store Online
Hope it’s helpful.
Are there any GaN chargers that would drive the ZimaBlade? I can’t find anything that does PD 12v3a.
