Zimablade LED control
Is it possible to turn off the LED? The BIOS has no option. Also for the PCI adapter LED when using NVMe SSD on it. Too many blinking lights if using Zimablade on a dark place!
Hey, would you give us some photos of those LEDs? I know part of them may be capable of shutting down.
I would like to shut down these ones:
It appears that one is a SATA read/write status indicator, and the other is a PCIe power status indicator. Both are passively triggered, so they likely cannot be manually turned off.
Sometimes, black tape or paint is the best way to fix annoying LEDs, especially those under hardware, not software, control.
