Zimablade lan not working
I bought a Zimablade, but the network doesn’t work, no blinking, and no activity even when I try to change the operating system. I contacted support, but I haven’t heard back in two days. What can I do?
Zima send me a new board but Lan is not working, neither dhcp or static ip. Is it normal to dont have any light on lan connector? even a 30$ oranga pi have led light to show activity…
Have you tried connecting a monitor to check the system status? Confirm that the device can boot into the system normally before proceeding with further troubleshooting. And…yep, Zimablade’s network port indeed lacks indicator lights, most likely due to size considerations.
already tested static ip and dhcp settings by using monitor and keyboard but with no luck. This is the seconds unit that fails to connect to my company UniFi lan router. We have servers, sbc by odroid, raspberry, olimex, dwin panels, laptop and desktop and we never had problems like that, and I never seen a board with no activity led…
Could you please provide the output logs or screenshots of the ip a and lspci commands? We want to confirm whether the hardware has been recognized and the IP configuration. Thank you. If uploading files or screenshots is inconvenient on the forum, you can send the information to support@icewhale.org.
Doesn’t matter, I decided to sell it as “no lan working” device on ebay. Thank you…
