ZimaBlade and USB C Hubs / Docks
The ZimaBlade has one USB C socket, that server as both an IO port and the power port in.
For anyone wondering. USB C adapters can expand ports but they MUST allow power pass through.
As some examples I have a Dell DA300 USB-C MiniDock / adapter that has Ethernet, USBA and USB C as well as VGA/HDMI and DP out. However it more of a dock and cannot be used to add monitor in an extended Desktop Mode is only mirrors the same video out.
This DOES NOT work with ZimaBlade as it does not have power passthrough so cannot power the ZimaBlade
On the other hand my Selore&S-Global 14 in 1 Adapter which DOES have power pass through works fine to add more ports. This DOES wortk with ZimaBlade I can see the ZimaBlades video out on the HDMI and VGA output of this Dock. I don’t have a DP enabled monitor but have no reason to think it will not allow DP out.
This dock is capable of outputting three video outs to different monitors, however that does depend on your setup. My ZimaBlade is currently running the stock Debian and CasaOS, as such it does not have a graphcial interface and I do not think its possible to use extended mode on command line Debian so the output is in mirror mode.
It has also been confirmed that the IceWhale Cyberize 1 DOES WORK as a power supply and as a pass through adapter.
NOTE: It is highly recommented that you use good quality USB C cables. Poor quality cables may have thin wiring cores, or not be filly wired, and may not perform as expected.
Apparently Dell DA310 supports power pass through.
I have this model but I am still waiting for my ZimaBlade to arrive. Once I test I will write here and confirm.
hi, i got this USB-C Hub from Anker, i can charge my phone with it, but the Blade wont start up :frowning:
My usb charger has PD 100… any idea ? tried a lot of different cables…
Please look at the small print on the USB charger, does it say it can output 12V /3A?
ok … tried it only on USB-C2 …12V 3A , max 100W … wont work. USB-C1 works … why XD
nvm sorry mates and thx
the original zimablade charger doesnt work either …12V 3A
I can’t really make out the letters, but the original Zima charger is a dumb charger, it does not do USB PD only outputs the 12V/3A. If that doesn’t work with the dock it suggests the dock may be doing something to signal voltages needed to the PSU.
That said I’m not sure why one socket works, I’d have expected that dock/hub doesn’t fully support pass through then none would work.
i cant tell the difference between port 1 and 2 of this charges, exept that max power output is 140W and 100W … the 100W wont work. nvm, found the solution :wink:
thank you and have a goot day/night what ever timezone you are in :smiley:
Does the IceWhale Cyberize 1 work as a hub…ie usb ports and the HDMI or only for charging and pass through charging
Not missed this, I’ve just not had time to try. One of my blades runs my Home Assistant, the others one for testing is in a cupboard, and its been a busy week. Will try to get and test over the weekend at the latest.
Looks to allow access to the hardware in CyberizeOne. This is my Spare Blade, I’m using the CyberizeOne as the PSU.
You can see the Cyberize Ones 1TB drive is shown as SDA2 ( highlighted in RED)
Then I put a USB memory stich in the CyberizeOne and it appeared as SDB1 (Green box)
