Zima os out of space
hi i’m new to zimaos i’m using 1.5.1 beta
in a virtualbox VM
i made a 32gb boot disk
i have installed pihole, immich , jellyfin and duckdns
toda i found out that it’s running out of space. my question is i changed my drive size in virtualbox to 64gb now i would like to tell Zimaos that the disk is larger and expand to meet this new size how would i go about doing that, or can i backup my settings and apps reinstall and restore my settings
I don’t believe ZimaOS is supported running it via a VM, although some people can get it to work. I am running a Proxmox VM of ZimaOS and it works great.
But… you have to create a boot drive, THEN create an OS drive for it to work correctly.
