Zima os client nolonger connects
ever since upgrade to 1.6.1 i can no access my zimaos using zima client or thru samba
before 1.6.1 i could use zima client on my samsung s25 , after upgrade this seems to no longer work .
zima client can’t find machine even when i’m on same network.
Have you tried logging in using your IP address? By the way, what version is your phone?
HI 777-Spider
yes i did those my phone is a samsung s25 ultra
thanks for the reply but i solved to problem my boot drive had some problems. i performed a hard shutdown of pc then rebooted it took about 2 minutes then switch to next boot partition (slot b)
every thing works now . now i just need to figure out how to setup jellyfin
thanks for your help .
