When I install docker apps via Appstore, I usually change container version to “latest”. Zima 1.3.0 then flags them as needing update (see image), and when applied, rolls them back to older versions. Any way to prevent this?
Sorry, it looks like this is a bug and we’ll try to fix it. For now a good best practice is to use specific version numbers instead of latest.
The Bug have fixed in 1.3.1. Do your problem be sovled?
Yes - I think so. I had also followed other advice (use specific version numbers) so haven’t had the issue again.
This bug still persists, in version 1.3.1-1, at least for me.
Would you plesae provide more detailed info? What app? what version?
I happened to have Syncthing App to update, but it happens to me every time I update. I am sending a video of the update process.
The version of Zimaos is 1.3.1-1
Im sorry as a ne user I can’t upload attachments, let me know if there is another method to send it.
I’m using version 1.3.1-1 and I have the same issue.
