My ZimaCube runs 24/7 so it makes sense to have an exit node in this state. My son will be overseas for most of the next year and having this as a VPN option is my hope and one that isn’t timezone dependant.
I have played with Tailscale on ZimaOS, but had difficulty in getting it to run as an exit node. Are there any instructions available to properly set this up in this exact environment (ZimaOS)?
I also succeeded by simply opening the Bash panel of the Tailscale container and pasting:
tailscale up --advertise-exit-node --reset
This command was suggested in the Tailscale admin panel, and I added --reset as recommended by the bash itself.
I am studying Docker and Linux systems, as well as networking recently, so I’m not able to understand the meaning of IP forwarding and NAT routing commands. I wanted to share a very simple solution for newcomers like myself
