This is a list of possible English translation and visual differences found in ZimaClient Android that might be simple to check ![]()
Click on ZimaOS device to start the SimaOS login screen. On this login screen, there are several different fonts and sizes - âZimaOSâ is very small, âPasswordâ different font, etc.
After login, in the Profile page. Under âHelp Centreâ, there is an Mandarin title with âsupport@icewhale.orgâ to the right.
Selecting a backup path to ZimaOS destination - âSelect folderâ is in Mandarin. Also, when the folder is empty of subfolders, there is no indication of âNo subfolders foundâ which might usually be shown here.
Create a new folder for Backup on ZimaOS - âProvide folder nameâ label is missing from prompt.
I hope this is of assistance. Please close if you are already aware of these. I am sorry this is a duplicate from GitHub, I could not find any place mentioning where to log ZimaOS Client issues, particularly for Android
From App: Version 1.0
From App Store: Version 1.0.1 (4 Jul 2025), Asus ASUS_AI2302
System: ZenFone 10, Android 15, System Language English (New Zealand).
xiexie - Gene
