Yaml Generate Tool
Yaml Generate Tool
We are glad to introduce a practical app tool for CasaOS - Yaml generator!
This tool provides a clean interface where you can input app parameters, CasaOS related description and WebUI link. It will generate the corresponding YAML file based on the provided inputs.
This generator simplifies the YAML generation process and ensures the generated YAML files are valid and properly formatted.
Try it! :point_right: Yaml Generate Tool
Also it is available as open source :point_right: check the code on Github
:heart: Many thanks to @Cp0204 for developing such a great tool! As a CasaOS community developer, he also contributes to CasaOS app ecosystem. You can check his app store on Github: Cp0204-CasaOS App Store-Play
