Wireguard CLIENT
I am trying to add a wireguard VPN client, using a custom containerized application.
I have tryed infinite combinations but apparently there are some kernel limitations that do not allow to use a wireguard client. Is this confirmed by anyone?
Has anyone been able to connect to a wireguard vpn? (not use zima as a SERVER)
Hi, I’m using Wireguard in conjunction with the Fr!tzBox, and it works great. I also use Zima as a server.
thank you for the feedback. Unfortunately my router does not have a VPN configuration possible
