While changing the icon of one of my web shortcuts, the interface suddenly froze. After refreshing the page, all of my Internet/web shortcuts had disappeared.
They were not installed apps, just web links that appeared as app icons on the dashboard.
My Docker containers and installed apps are all still there. Only the Internet/web shortcuts are gone.
Does anyone know where ZimaOS stores the Internet/web shortcuts?
All of my web shortcuts disappeared after the interface froze while I was changing the icon of one of them.
I’m looking for the folder or configuration file where these web shortcuts are stored. If I can locate the files, I may be able to recover them instead of recreating every shortcut from scratch.
Any information would be greatly appreciated. Thanks!
I don’t know the exact ZimaOS shortcut database path yet, so I don’t want to give you the wrong file name.
Because the shortcuts disappeared after the UI froze while changing an icon, I would treat this as possible dashboard metadata corruption, not a Docker/app issue.
I would first search for one of the missing shortcut names or URLs:
Do not edit or delete anything yet. If the records still exist, they may be recoverable. If they were overwritten, restoring the relevant metadata from a /DATA/AppData backup may be the safest option.
Maybe IceWhale can confirm the exact location where ZimaOS stores Internet/web shortcut records.
Hi, may I ask which version you are currently on?
You can run the following two commands and send us the results. You can reply directly or contact me via email: dina@icewhale.org
Hi, can you provide the icon address you modified at that time? Also, if you try the same action to modify the icon now, will the webpage shortcut still be lost?
Unfortunately, I don’t remember the exact icon URL that I was modifying at the time.
I have tried changing the icon of a newly created web shortcut several times since then, and I have not been able to reproduce the issue. Everything works normally now.
The problem only happened once. While changing the icon, the UI suddenly froze. After refreshing the page, all of my existing web shortcuts had disappeared.
Since then, I have created a backup of link.json and app_order.json to avoid losing them again if this happens in the future.
If I notice anything else or manage to reproduce the problem again, I’ll let you know. In the meantime, I’ve started backing up link.json and app_order.json regularly as a precaution.
