We Need Feedback on ZVM
ZimaOS partners, your voice counts! Our voting campaign for ZVM feature improvements is still ongoing. Currently, features A (support for more formats of mirrors), D (easier access to mirrors), H (allow importing of instances exported from other VMs), and J (support for lxc) have gained more attention.
:star2: We encourage you to keep voting and especially welcome more feedback and new requirements. Your input will directly influence the direction of our development and help us build a more user-friendly ZVM.If there are other features or improvements you’d like to see, please don’t hesitate to leave a comment below or show your support by voting!
:point_right: Click here to vote and leave a comment, and together we will shape the future of ZimaOS! Discord
Thank you for your active participation and valuable feedback, let’s push ZimaOS to a higher level together! :rocket:
It would be fantastic for PCI passthrough to allow the VM to directly access GPU and hardware resources.
please bring support for more installation image formats like raw vm images.vdi, .qcow2, .ova withought having to convert to .iso. thank you team.
I second this. At least qcow2 would be great to be supported.
Just got my ZimaCube so I’ve not used it a lot yet, but it looks like the creation process expects an ISO installation file. I think there are a fair amount of VM “appliances” out there that don’t have an installation process, but rather a qcow2 file (or the package VMware uses) that lets you drop it in, boot up, and the appliance is active. I have one in particular that uses qcow2 format that I would like to run. (I’ve been able to run it on QNAP and UnRaid.)
It would be nice to be able to install Home Assistant OS in zvm.
Currently I can’t, because they don’t provide an iso to install, only an image with the OS pre-installed…
I second that. At this point ZVM only let you use iso images. Not even img, which HAOS has.
Hi,
First off, I just want to say a huge thank you for the incredible work on Zima OS !
I’m currently running it on a DIY NAS built from an old gaming rig (Ryzen 8c/16t CPU and RTX 2070), and it’s been smooth overall.
That said, I’ve hit a snag with virtual machines. I tried setting up two VMs (using ZVM) :
  • One Windows 11
  • One intended to be a headless SteamOS gaming VM
In both cases, it seems like the GPU isn’t being utilized at all. From what I understand, Zima OS doesn’t support PCI passthrough at the moment, but even without that, I was expecting at least basic GPU acceleration for the Windows VM. But performance was sluggish, and it seams the CPU was handling all the graphics rendering.
I’m wondering if I may have missed a setting. Either in the VM configuration or somewhere else in the desktop environment. Has anyone successfully enabled GPU acceleration in their VMs, or is this a current limitation of ZVM?
If direct passthrough isn’t possible yet, are there recommended workarounds, maybe using a different VM manager on top of Zima OS, or another method to enable GPU access for better performance? Or any other ideas for one of the two VM I mentioned.
Thanks again for building such an impressive OS, really appreciate all the hard work going into it!
Cant seem to figure out how to make sure my debian server vm boots automatically after reboot. Would be nice to be able to toggle that option on or off per vm
@jordandroid @MrSkrumpkin Copy them. The team will talk about it.
I have a feedback for ZVM. Since ZVM is actually using libvirt, qemu, virsh, give us the option to enter our own commands for qemu for advanced users. And also to install cockpit-machines so that I can manage the virtual machine from cockpit
Would you please tell us if you get these privileges, what you will do specifically?
Previously on another topic, i have requested for the audio passthrough and your team says it’s not possible for Windows VM. So how about linux based VMs. And also the resolution issue, I’m hoping that it’s possible to use 2560x1440. I’ve rewritten scripts in linux to enable it, but it’s troublesome to keep anding it to different linux based machines. Actually my monitor can support 4k. however I know that 4k has an issue with the width as it is locked to 2560 width max. These are the things I’m hoping that I can try using the qemu commands to modify the VM startup to try to fix the issues
For the cockpit-machines, is to have a GUI way to handle resizing the VM storage pool
Copy that. We will talk about it.
i think it is so sluggish because it a docker. so it just can use what got set in the docker settings… sry for my bad english
Hi, use sudo -i so that you gain the needed privilege.
im new to zimaOS.. tough old timer on linux ;-).
just got my zimaboard 2 and the zvm both the prev. and 1.5.0 i get this below error when using the link for download of iso link the linked debian iso
tough if i find a url my self on debians or others homepage it downloads fine..
i guess you know this, i have just not found it reported.
would be nice if one could see what link/url that is not working and not just an error message.
Thanks for the feedback. I’ll log this and forward it to the team.
So, pretty much Look at VMware and do that in ZVM
