"Virtual machine" will been launched
Zima Virtual Machine (ZVM)
  • Virtual system: Ubuntu, OpenWRT, Debian, Windows, BSD, etc. System
  • Software licensing: Free for ZimaCube users
Feedback
Over the past week, more than 10 partners have experienced ZVM
  • NeoFight: I will start with home assistant
  • Eclipse: @NeoFight so excited
Watch the screen recording and tell the IceWhale team what you want!
ZVM
Later this week, an OTA push upgrade to experience the ZVM
Hi!
Only for ZImaCube or also for ZimaBoard?
This will work on ZimaBoard and ZimaBlade but obviously remember performance will vary depending on resources
Have someone managed to install Home Assistant OS in a VM and can make me a short tutorial ? I’m kind of a noob and I can’t get it to work :sweat_smile:
Hi,
This works on top of qemu or other manager or it’s 100% developed by ZimaOS?
What’s the performance difference compared to qemu + libvirt (Virtual Machine Manager from Store)
Thanks!
Its KVM+QEMU and no they didn’t develop those opensource projects.
There will be no perf difference, the virtual machine manager app is just a management UI on top of the underlying KVM+QEMU.
Libvirt is a single consistent library to manage virtual environments, it will have no direct effect on speed of whatever virtualization system it is managing.
KVM+QEMU+Libvirt are all installed, libvirtd seems to be running, i have been unable to connect to with VMM, but i am not a VMM expert so i probably did something wrong
FWIW, I tried to follow the instructions listed in the “Tips” section of the image, and I have been consistantly getting that libvirt can’t connect to qemu://system due to the daemon not running. I spent a fair amount of time looking around for a solution to this, but as of now, I’ve been unable to get this working. Like SeeDborg, I’ve been trying to get this working so that I can attempt to spin up the HAOS img file, as ZVM does not accept anything but ISO’s.
The next version zimaos1.2.5 will support img, .qcow2, .vmdk, and .vdi formats.
And now the beta version has been released, are you interested in experiencing it in advance?
I had same problems too… Won’t connect qemu://system to daemon is not functional at all.
Any Idea get this fix?? I am on ZimaOS v1.7.1-beta2 now..
Thanks.
First, you need to write what hardware you are running this on.
